Fluid force does not work properly - Printable Version
+--- Thread: Fluid force does not work properly (/thread-1307.html)
Fluid force does not work properly - jidpiaoxue - 11-28-2019
During the work test, it was found that fluid force and birth fluid did not work properly. No effect. Neither fume nor Phoenix can achieve the effect. The speed channel is output. Can you help me see what's wrong? The file is very simple. Thank you
RE: Fluid force does not work properly - tyFlow - 11-28-2019
Make sure you have the latest version of FFX/Phx installed Smile
RE: Fluid force does not work properly - jidpiaoxue - 11-28-2019
(11-28-2019, 08:38 AM)tyFlow Wrote: Make sure you have the latest version of FFX/Phx installed Smile
Thank you for your reply.
Yes, I'm sure I'll install the latest version
tyflow 0.16059
FFX 5.0.2
Big Grin
5.0.4 is the latest FFX version....
(11-28-2019, 09:16 AM)tyFlow Wrote: 5.0.4 is the latest FFX version....
Can 5.0.4 solve this problem?
Yes.
(11-28-2019, 09:22 AM)tyFlow Wrote: Yes.
Thank you. I'll try
