Instaced geometry has no material inherited - Printable Version
+- tyFlow Forum (http://forum.tyflow.com)
+-- Forum: tyFlow Discussion (http://forum.tyflow.com/forum-1.html)
+--- Forum: General Discussion (http://forum.tyflow.com/forum-2.html)
+--- Thread: Instaced geometry has no material inherited (/thread-1436.html)
Instaced geometry has no material inherited - tymc - 02-07-2020
Hi there,
it is probably my noobness, that is the real issue here and you guys know this on the spot, but this is the problem I am having:
I have several 3d-objects in my scene, which all have different vray-materials applied to them. In tyflow I am referencing these objects via a Shape-operator and although I checked the "Inherit from reference" option in the operator I cannot get the original materials rendered.
The geometry is rendering just fine, but with a weird yellow color.
What am I doing wrong? I used to do stuff in Particle Flow ages ago, but that is not helping me now a bit.
Please help!
Thanks!
RE: Instaced geometry has no material inherited - tyFlow - 02-07-2020
You're rendering as instances?
You can use a Display Data operator to check that the materials are actually getting assigned to the particles...
RE: Instaced geometry has no material inherited - tymc - 02-13-2020
(02-07-2020, 10:25 PM)tyFlow Wrote: You're rendering as instances?
Thank you so much for your reply! As it turned out, the particles were not receiving any material. The message read "mtl:[cache N/A]" and they were rendering with the 3ds max color from the tyflow-object.
It seems that the problem was, that I put a group of several mesh-objects into the Shape-node to be instanced as particles. It instanced the geo but did not find a material. I attached everything to one single mesh and render as "vray instances" and now everything works!
Thanks very much!
