Ink Drop - Printable Version
+- tyFlow Forum (http://forum.tyflow.com)
+-- Forum: tyFlow Discussion (http://forum.tyflow.com/forum-1.html)
+--- Forum: Gallery (http://forum.tyflow.com/forum-5.html)
+--- Thread: Ink Drop (/thread-1803.html)
Ink Drop - shadowkiller - 07-01-2020
Hey everyone!
I figured i would finally contribute something to the gallery after lurking around here for ages. This is an ink in water simulation that i have been experimenting with for quite some time. I made it as an animated wallpaper for my smart phone. Big Grin
Its a fumefx simulation with tyflow particles following it. The color mixing is also being handled by tyflow. The base sim has 10 million particles and 600 frames, it is multiplied 40x with the prt cache for a total of 400 million (4.6TB on my HHD) and slowed down 3x using motion vectors. I am rendering it with krakatoa.
Enjoy! Big Grin
https://www.youtube.com/watch?v=7gKFAqoJGu8
RE: Ink Drop - TubeSmokeGuy - 07-02-2020
Hey, as for the result this looks very amazing and beautyful!  Smile I like it!
But please don't get this wrong, I think the workflow is quite a little bit overkill and obsolete?   Blush
Was this for personal testing purposes (as you ment experimenting)? Otherwise for an effective production workflow you can achieve a similar result much faster and with less ressources by using f.e. PhoenixFD and render it as volume instead of a particle point cloud.
RE: Ink Drop - shadowkiller - 07-02-2020
Thanks, I appreciate it. Big Grin
The workflow is quite old yes, however i wouldnt say obsolete, there are still some things particles can do that voxels cant. Wink This whole process was largely just me experimenting to see how far i could push it by combining most of the techniques i have learned up to this point. Smile
There are a few reasons why i decided to go this route. A few things are happening that neither fume nor phoenix can do on their own. The main one being the color mixing. Fume/phoenix use additive color mixing, the more colors you add the closer to white you get. I wanted subtractive color mixing for this so i can get the third color when the 2 mix, in this case the green. By using tyflow to control the mixing i also have much more fine control over how it mixes, from the mixing radius down to how fast it mixes. Since the mixing is controlled by gradients they could be entirely non-physical if i wanted. You have zero control over that in fume/phoenix.
I chose to go with fumefx because i suspect there is a bug with how the particles follow the phoenix grid. I was unable to get the particles to match the smoke as well as i could with fume. It was as if the particles was sampling the velocity grid from the from the frame AFTER your current one. The particles always seemed to be 1 frame ahead of the smoke, regardless of the amount of sub-frame steps. I would have very much liked to use phoenix instead of fume for this since i prefer the visual style of the smoke a bit more than the fume one, its more realistic looking. This was a problem for me because the krakatoa caches are sampling the density of the voxel grid. If the particles dont match the smoke then it can lead to odd artifacts such as holes in the sim where the particles drift outside the density field. I also use the density gradient to calculate normals with magma so if the particles don't match, neither will the normals. Sad
Another reason why i chose particles over voxels was for the shading and detail. In order to reach that level of fidelity on a voxel grid the resolution would have to be crazy high. Even then you cant get the same amount of variation in density since the particles are physically moving and clumping together which creates a more natural look. This especially helps with the color mixing since it tends to create strands of overlapping color instead of a general diffuse mixture. I also wanted some form of specular on this so it would appear shiny and krakatoa allows me to render with various different shading modes. I am manipulating the particles in various ways with krakatoa's magma editor, such as tweaking the absorption colors/densities/normals etc.
The last trick i used was to render the final effect at 1/2 resolution and then use an AI up-scaler to smooth out the dots generated by the particles. Rendering at 1/2 resolution also increases the density of points in the render due to how the point rendering works so this reduced any noise even further.
RE: Ink Drop - TubeSmokeGuy - 07-03-2020
Thanks for your detailed answer. It all makes sense to me Big Grin! What I would recommend to you is to confront the PhxFD devs with your expieriences that you got discribed here (f.e. in their forums or on facebook). I made the expierience that they handle issues seriously and are very eager to help. Maybe they can show you some tricks to reach your desired effect just by using PHX.
With fume I never got in touch.
