Position Object OR spread opeartor extension: Surface Offset OR Spread by Texture - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Feature Requests (https://forum.tyflow.com/forum-4.html) +--- Thread: Position Object OR spread opeartor extension: Surface Offset OR Spread by Texture (/thread-1841.html) |
Position Object OR spread opeartor extension: Surface Offset OR Spread by Texture - TubeSmokeGuy - 07-15-2020 Hi! As the topic name says, it would be cool if the position object operator can get a multiplier by texture for the surface offset. Or the spread operator gets a multiplier by texture for the spread amount from an object selection. Here some pics how I imagine that: The last pic is fake and should just show which effect I have in mind. Greetings! RE: Position Object OR spread opeartor extension: Surface Offset OR Spread by Texture - tyFlow - 07-23-2020 Not a bad idea, I'll make a note in the roadmap. RE: Position Object OR spread opeartor extension: Surface Offset OR Spread by Texture - TubeSmokeGuy - 07-24-2020 Cool! Thank you! RE: Position Object OR spread opeartor extension: Surface Offset OR Spread by Texture - TubeSmokeGuy - 10-23-2020 (07-23-2020, 02:07 AM)tyFlow Wrote: Not a bad idea, I'll make a note in the roadmap. Hi! Some time has passed. I would like to ask if there is any progress going on here? |
