tyFlow v0.16095 (BETA) - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Latest Builds (https://forum.tyflow.com/forum-6.html) +--- Thread: tyFlow v0.16095 (BETA) (/thread-2044.html) |
tyFlow v0.16095 (BETA) - tyFlow - 11-11-2020 tyFlow v0.16095 is up! http://beta.tyflow.com Additions: * improved handling of cloth forces through Force operator (can enable this new handling method with addition of "cloth aerodynamics" toggle in Force operator) * keyframe rollout added to Custom Properties operator * added verlet integration option to Object Bind operator's rotation settings, for transfering angular momentum to particles from bind movement Fixes: * fixed a critical issue that could cause Max to become unstable/crash when more than 30 tyFlows exist in a scene (operator icon GDI object overflow) * fixed an issue where new tyFlow 'x' menu items were not appearing in Max 2020 and below * fixed a bug where a tyMesher could crash in certain circumstances if UVW data on input meshes was corrupted * fixed an issue where the tySplineMesher modifier was not updating properly if its input meshes were animated/deforming * seed value in Scale operator is now keyable * fixed an issue where inflation applied to 2D cloth meshes would introduce a lot of angular momentum * fixed an issue in the Mapping operator where decoupling source/target UVW channels was not working correctly * fixed an issue where the tyConform modifier was not adjusting spline tangents * fixed an issue where tyActor animations were not properly transferring angular momentum to particles * greatly improved accuracy of tyMesher UVW inheritance * fixed an issue where tyCache objects weren't properly processing certain simulation group comparisons |
