tyFlow v0.16097 (BETA) - Printable Version
+--- Thread: tyFlow v0.16097 (BETA) (/thread-2075.html)
tyFlow v0.16097 (BETA) - tyFlow - 11-27-2020
tyFlow v0.16097 is out!
http://beta.tyflow.com
* added Temporal Smooth operator for smoothing particle motion over time
* added relative float options to Modify Bindings operator (see docs for more info)
* added auto-freeze option to the tyUVWFreeze modifier
* added node-based raycast mode to tySelect modifier
* added 'pinched vertex' selection mode to tySelect
* added tyVertexChamfer modifier for chamfering (ideally pinched) vertices (see docs for more info)
* fixed regression causing tySelect to crash when used on editable poly objects
* improved performance of Modify Bindings operator on large cloth meshes
* fixed a bug where keyframing settings could crash the Modify Bindings operator
* fixed a bug causing a pretty substantial memory leak during cloth/actor mesh retrieval
RE: tyFlow v0.16097 (BETA) - ThomasHorsley - 12-04-2020
Is there a way to download older versions? --- v.016096 ??
I keep getting warnings on Windows 10 Pro saying there is a virus threat in the zip of version v.016097
Is anyone else having the same issue?
RE: tyFlow v0.16097 (BETA) - tyFlow - 12-04-2020
It's a false positive. You can use virustotal.com to see that the download zip and the individual .dlos are all clean.
Thank you Tyson -
All sorted now.
