tyFlow v0.16104 (BETA) - Printable Version +- tyFlow Forum (http://forum.tyflow.com) +-- Forum: tyFlow Discussion (http://forum.tyflow.com/forum-1.html) +--- Forum: Latest Builds (http://forum.tyflow.com/forum-6.html) +--- Thread: tyFlow v0.16104 (BETA) (/thread-2171.html) |
tyFlow v0.16104 (BETA) - tyFlow - 01-22-2021 tyFlow v0.16104 is out! http://beta.tyflow.com Additions: * added $tySwitcherIndex as path symbol to Export Particles operator, for including switcher index override in filename * added MXS functions for submitting PRT/tyCache jobs to deadline from Export Particles operator * added GetParentID function to Script operator * added "Direction to Target" vector option in Custom Properties operator and "Distance to Target" float option in Custom Properties operator * added timing/filter rollouts to Shape Remove operator * added "On Shape Vertices" mode to Spawn operator * added line offset option to Display Data operator Fixes: * fixed an issue where a tyActor referencing deleted/missing particles in a cache or flow could cause a crash. * vastly improved performance of tyConform modifier on input splines with a huge number of segments/knots * fixed an issue where putting a tyParticleSkin on a mesh with underlying deformations would give an improper result * improved performance of Modify Bindings operator on large collections of binds * fixed an issue where the Display Data operator was not displaying correct radius values * fixed a bug that could cause Max to crash if a particle hits a PhysX Mesh collider when CUDA is enabled * improved PhysX performance (up to 2x in some cases) when not using an operator reliant on contact reporting (contact reporting ops are: PhysX Collision with valid output connection, Spawn set to PhysX Contact mode, and Voronoi Fracture set to PhysX Contact mode) |
