tyFlow v0.16112 (BETA) - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Latest Builds (https://forum.tyflow.com/forum-6.html) +--- Thread: tyFlow v0.16112 (BETA) (/thread-2280.html) |
tyFlow v0.16112 (BETA) - tyFlow - 03-13-2021 tyFlow v0.16112 is up! http://beta.tyflow.com Additions: * added more options to the spinner right-click "set keys" menu * added trajectory interpolation settings to tySplines object * added option to delete particles in Camera Cull operator * split "default lights" tyPreview option into "1 light" and "2 light" options * Display operator "custom float" and "velocity magnitude" color modes will now be multiplied by operator color picker value (so they will tint the selected color, instead of merely appearing as a black and white gradient) * added new "polygons" option to Birth Surface operator, and renamed "faces" option to "triangles" Fixes: * Shape operator instance material inheritance now works on group members, when "split group members" is enabled * changed Object Bind proximity setting to be more intuitive, using distance to closest surface point, rather than projected offset point to do proximity calculations * fixed an issue where instanced pblock controllers inside flows would not survive file save/load * fixed a PhysX Fluid operator race condition * fixed an issue where Growth operator SC algorithm was not sending particles out when connected to another event * fixed an issue where PRT export would not export all custFloat/Vec channels in some cases * fixed an issue where changing an operator's timing from the right-click menu was disconnecting it from any attached events * fixed an issue where resample angle binds would result in a crash (by disabling angle bind resampling, since it should not be possible in the first place). Furthermore, made it so only stretch binds can be resampled (ie, shear/bend/volume are also excluded) * fixed an issue where duplicating a flow could result in incorrect Particle Bind operator viewport bind display * fixed some issues related to how the Resample operator determines siblings relationships between new particles * fixed an issue where changing a tyCache setting wouldn't update viewport display until the time slider was moved * fixed a crash that could occur in some setups during cloth collision initialization RE: tyFlow v0.16112 (BETA) - devailo - 03-15-2021 When i do a Ty preview - i use the most basic settings, and when it finished making the preview it changes my viewports to <user defined> its getting a pain to switch ti back to standart everytime . Previous versions didnt have this problem. |
