TyConform: add "relax over source geometry" - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Feature Requests (https://forum.tyflow.com/forum-4.html) +--- Thread: TyConform: add "relax over source geometry" (/thread-769.html) |
TyConform: add "relax over source geometry" - Zemmu - 06-08-2019 Hi, tyconform is amazing, simple and powerful. Something that would help a lot would be a "relax over source geometry", so we could have an even geometry, ready for tyflow cloth RE: TyConform: add "relax over source geometry" - tyFlow - 06-08-2019 Could you give an example of what you mean? RE: TyConform: add "relax over source geometry" - Zemmu - 06-08-2019 Something like toporelax: https://mariussilaghi.com/products/toporelax Right now the conformed geometry hasn't an even geometry (I tried all modes), very dense areas mixed with areas with long edges and very few vertices. I'd like the conformed geometry to "slide" over the destination geometry until edges lenghts are as much similar as possible. RE: TyConform: add "relax over source geometry" - tyFlow - 06-08-2019 That's a bit beyond the scope of what the tyConform mod is designed to do....perhaps you could stack 2 tyConforms and put the toporelax between them? So you'd get the relaxation but also a re-conform after that to keep the verts hugging the target surface. RE: TyConform: add "relax over source geometry" - Zemmu - 06-11-2019 (06-08-2019, 09:39 PM)tyFlow Wrote: That's a bit beyond the scope of what the tyConform mod is designed to do....perhaps you could stack 2 tyConforms and put the toporelax between them? So you'd get the relaxation but also a re-conform after that to keep the verts hugging the target surface. I'll try! |
