abc Multi/Sub-Objiect to UE4 - Printable Version
+--- Thread: abc Multi/Sub-Objiect to UE4 (/thread-886.html)
abc Multi/Sub-Objiect to UE4 - chrisucdos - 07-11-2019
HI! TYflow is a great tool, but the exported ABC has only one shader into UE4. I want to support multiple shaders like a Attachments.thank!
RE: abc Multi/Sub-Objiect to UE4 - tyFlow - 07-11-2019
tyFlow's alembic export currently only supports the default UV channel. You can try max's default alembic exporter in the meantime, just make sure to add Mesh operators to all events you want to export and turn 'render only' off.
RE: abc Multi/Sub-Objiect to UE4 - chrisucdos - 07-11-2019
(07-11-2019, 08:22 AM)tyFlow Wrote: tyFlow's alembic export currently only supports the default UV channel. You can try max's default alembic exporter in the meantime, just make sure to add Mesh operators to all events you want to export and turn 'render only' off.
Thank you for your reply. I hope to upgrade more support for UE4 in the future, such as Flowmap   Vector Field    Actor AI  Export FBX.
Thank you for everything you have done.
