Voronoi: "Show cloud points" not showing points
when I check at the Voronoi Fracture "show cloud points" it is not showing them.
I this a new bug or does it need something else to work?
(Looking with edged face and Clay mode, but also in other view modes I can't see them)
Is your timeslider set to the frame that fracture is occurring? It'll only show points on fracture frames.
Make sure there are no modifiers on your tyFlow either, or they're at least disabled when you want to see points. Max won't call BaseObject display functions if modifiers are present.
Thanks I solved it somehow.
Also with refresh, toggle tyflow on/off, delet cache and so on - not sure which exactly helped, but then it worked. It was already the start frame.
