Solo simulation mode
I want the function that Simulate only the selected tree.
And also, When select multiple events, I want to turn them Off/On at once(Based on the state of the clicked event)
Thank you.
Multi on-off is possible and can be added to the todo list, but simulating an isolated set of events is not. An alternative is just creating multiple tyFlow objects in your scene and keeping them separated that way.
I got it! Thank you Smile
I came up with a new idea!
In large scenes, it is hard to select event lines each time and connect and delete them one by one.
So, When select multiple, I feel need shortcut.
example: push ctrl and rectangle selection, move to multiple selection mode
Thank you.
