Particles filling an object (box)
Hi all
Newbie, trying a few ideas. I've followed a few tutorials and set up a simple scene.
Any help would be greatly appreciated. If not a link to something similar.
1) I would like to have particles spawn from above, the particles are 3d Geometry (stones shapes) and fill a box, but not to overflow or break the edge, trying to keep a clean edge. So far I can get the box to fill - ish, but it's not great.
2) Is there a way to turn the particles into a mesh, not to animate just to render a still?
Thank you
.max   Tyflow_01e.max (Size: 696 KB / Downloads: 555)
I'd also love to know how to do this too!
I'm trying to fill a glass with ice cubes but they aren't constrained to the mesh and also not interacting with each other as they should.
Not sure what's the problem guys.
I had some free time, and I did it quickly.
2 things I only changed in Physics.
1) In the physX shape operator, I checked "ignore start penetrations",. so the ice cube don't collide immediately when spawned.
2) In the physX Collision operator, I changed the "hull type" to mesh, so it doesn't simplify geometry.
I didn't even increased timing substeps, and PhysX substems (but if your system are faster, you might consider that).
Here is the result:
https://youtu.be/Ik97zAu9A-U
Attaching you a scene file.
.zip   Ice_Cubes.zip (Size: 25.07 KB / Downloads: 541)
