Surface Test bug
Hello tyson, I just updated to the newest version and I think it is a bug which crashes max when I add objects in surface test operator. I created plane with 80 length and width segs, added in birth surface, added particle bind with bind distance of 2, set the particle group sim group 1 then created 4 boxes at the corners of the plane to deactivate them using surface test but when I add selected the boxes, max crashes and the file doesn't opens afterwards. Can you check it?
Thanks, will be fixed in tonight's build Smile
Stick with v0.16047 in the meantime.
Thankyou so much, you are great!
