TySelect Animated Texmap doesn't
Hi Tyson,
I tried the new TySelect Modifier which is really great, but I discovered an issue with animated Texmaps. The vertex selection doesn't update when the texture is animated. (I tried a standard noise with animated phase)
3ds Max 2020
Can you check that?
.max   TySelect.max (Size: 660 KB / Downloads: 215)
Thanks Manuel, I'll check that tonight.
Will be fixed in v0.16050.
(10-04-2019, 02:30 AM)tyFlow Wrote: Will be fixed in v0.16050
Works like a charm now. Thx!    Shy
