tyMesher Pick Button
Clicking the "Pick" Button on a tyMesher object won't cancel if you push it again. Esc key is the only way to get out of pick mode.
Khye
ESC or changing selection mode works. Unfortunately not fixable due to a technical limitation in the way max's pickbutton functionality is designed (tyFlow initializes pickbuttons dynamically but the press-to-leave-pickmode functionality only works with static pickbuttons).
