Changing noise pattern "seed" on the Force Node
Hi there,
I'm trying to get different variations in the noise pattern in the Force node.
Changing the seed only changes the distribution of the particles along the same noise pattern.
Is there a way to change the "seed" or position of the noise pattern itself?
I'm assuming I need to use the "Custom Vector" setting and pick a channel? In the list there are only 2 values - 0 and target.
However I can't find a clear enough explanation on how this works.
There's not and it's actually something I've been thinking about adding already....I'll make a note about it.
