"Spin" node adds a planet "revolving around the sun"
HI,Tyson!
This is not to change the axis of the particle. Instead, all particles will rotate around a custom object and still maintain the rotation of their own axis.
There is a recent project on planets. If you can add a "vortex" vector to the "Speed" node, you can really simplify a lot of processes.
Thank you
You can use the tyVortex helper in a Force operator to achieve this. Make sure you place a Slow operator above it, set to 100%, so the velocities are fully dampened.
