tyMesher does not render on deadline
Hello Tyson ,
when I put tyCache as input object in tyMesher, it does not render on Deadline but renders on local machine. What this can be possibly? bug? or I have to do something in order to render it on Deadline?
Sounds like your render nodes cannot see the cache files for whatever reason.
Try a tyMesher on a default object like a teapot and see if that works. I've rendered tyMeshers hundreds of times with Deadline without issue, so it seems like something else is causing the problem.
So, I was wrong before it is not the problem of render nodes, rendering the full sequence on the local machine also generates the same problem, i am able to render only a single frame.
Ok problem is weirdingly solved , i checked on force particle interface and then it worked, I don't know how but thank you.
