Property test: position % of the spline being followed
Hi Tyson,
dunno if this would be possible - does tyflow has a way to know at what % of the spline is the particle that uses path follow operator?
If so, could it be a property we can test?
There's no built-in way but you could use the Script operator to measure the distance to a vert on your spline, and then iterate all the verts on the spline to find out how far it is along.
