Nano tech effect
This is the closest I can get to replicating the nano tech effect in Avengers. Anyone know how i can improve it? I am using a brick fracture for the individual blocks but, this causes a non smooth surface while rendering and it's obvious. It also doesnt have much detail like the one in he movie. I tried thinking of a way to create a bunch of tiny little 'nano particles' instead of using a brick fracture.
.mp4   Iron_MAn_NAno_Tech_tst_preview_Trim-1.mp4 (Size: 123.38 KB / Downloads: 301)
I like it. :Smile
I don't think you should replace bricks, here's what I would do:
I'd definitely integrate rotation, and scale (animation) into them, not just to appear suddenly.
My samples are not representative (there's much better online), but I'd make rotation something like this I did with Particle flow:
https://www.youtube.com/watch?v=5WpUfmFSNOY
(there's a sample in Tyflow that rotates triangles in similar way).
And I'd make 2 or 3 passes of animation, something like I did here:
https://www.youtube.com/watch?v=cWUKIua9kDQ&t=5s
(when I say 2 passes... you see how I stop them for few frames at size of 90%, and then after a several frames they go from 90 to 100%)
So, in your case, maybe 3 passes, that use the same reveal approach (that you already have, and I like it).
1) Particles appear from 0 to 50% (animated scale), the same way they appear now)
hold them for 5-10 frames with "time test" operator
2) Particles rotate 90 or 180 degree
3) Particles scales from 50 to 100% size.
Now,. I am not sure how accurate this would be with some Avenger movie (never been a big fun), but that's something I would do.
