edge/corner fracture not working on "shape" operator cube
Hey Tyson
having issue with edge/corner fracture not working if using a "3d cube" from the dropdown list in the shape OP.
voronoi fracture works, but the edge/corner does not.
funny thing is if i replace it with a "scene geo cube" it works
iv posted a scene
got to frame 25 and turn on/off bottom shape op , you'll see what i meanĀ  Smile
btw 3ds max 2018 scene
kind regards
Harv
.max   ty-corner-error_01.max (Size: 532 KB / Downloads: 393)
Are you sure you just haven't compensated the Edge Fracture values for the scale of the default cube? Set the depth values to be a lot smaller than their defaults and see if that works.
(02-12-2020, 04:38 AM)tyFlow Wrote: Are you sure you just haven't compensated the Edge Fracture values for the scale of the default cube? Set the depth values to be a lot smaller than their defaults and see if that works.
that was exactly it Tyson!
thanksĀ  Smile
Harv
