Possible bug
Tymesher won't render in animation.
If I render still image - it's there.
If I start rendering animation, it won't render.
Tried to disable particle cache, same issue.
Vray 3,6 render, and I've tried both 69 and new 70 version.
Any ideas?
Attaching the file.
.rar   02_Magnet_scene_07_2017.rar (Size: 1.21 MB / Downloads: 37)
UPDATE   Cool
It seems that just adding a simple edit poly modifier to Tymesher, completely solved it.
So, if anyone have a problem, that's a quick fix.
Hmm I'm unable to reproduce this. If I render a sequence the tyMesher updates fine...
(02-14-2020, 08:10 AM)tyFlow Wrote: Hmm I'm unable to reproduce this. If I render a sequence the tyMesher updates fine...
Weird.
Some guy in the facebook group also tried, and couldn't render.
Maybe it's 3ds Max 2018 issue? If you're using 2017.
Here, I recorded you short video that shows the problem:
https://www.youtube.com/watch?v=hKOlpV0_...e=youtu.be
If it helps, I also noticed that it doesn't have this problem if I render in scanline or Vray RT.
Update: this should be fixed in v0.16079.
