Collision set to Continue - Particles pausing/stopping with non-zero radius
I'm finding that if I have a particle with shape assigned (cube) and run a Collision with Particle Interaction set to Continue, there is a pause in motion when the particle normally would bounce fi the Collision Radius is set  >0.0 or in Shape Radius or Scale Radius mode.   If you set the radius high enough the particle will get stuck in place at the birth position and never move.  I'm using a simple force with built-in gravity, but a max deflector spacewarp at the ground plane for collision.  Same thing happens if I use a plane for the collider instead.
Thanks for the report, I'll look into it.
Hey, this bug is fixed in the next build (v0.16008) which will be released shortly.
