Alembic Instances?
Hi there,
I think, not so sure, Max got an update some time ago to work with alembic instances, is there a way that TyFlow uses this?
The ABC created with Tyflow when used for parametric modelling is quite heavy compared to the TyCache.
I gave a look to the ABC exporter options but the only thing that, maaaybe could affect could be "mode" single collapsed node / node per particle but was greyed out when ABC.
16MB vs 997MB
I would like to use that Alembic inside Houdini also if it matters for something.
Thank you.
