Cloth interactions between separate items
Hello
I have a cloth simulation and I want to give the pieces of cloth different properties.
If I create them all at the same time using the same Birth Object how do I split them to do this?
If I create them separately from different Birth Objects how do I have them interact with each other?
If I use a skin wrap on some geo linked to a dense cloth simulation to simplify the surface and then want to run other cloth objects on that simplified surface if there a way to reference that in the same flow (but later along the chain) or am I forced to create a second tyflow system which would have be run as a second pass?
I did look at the flag example but did not find this answered my questions.
I have included a max file with 3 tyflows in as examples.
Thank you for any help Smile
.max   Cloth Test.max (Size: 876 KB / Downloads: 145)
