Hello fellows,
I am trying to export my tyflow setup as alembic to C4D,
one way I found on youtube is to select the tyflow object, export selected as alembic from the 3ds max file tab without having to do it from tyflow itself adding an Export Modifier,
However, In a setup where I have a tyactor this method does not work, the export in all cases even after putting the export modifier, is the keyframed object, not the simulation within tyflow,
I am attaching my project file with the tyactor, Hope you can help me out
bayza file dont know how to export.max (Size: 728 KB / Downloads: 174)
