06-10-2020, 10:56 AM
Hi all and thank you Tyson for so amazing plugin. Really helpful.
I have 2 objects in one simulation and I need to render them separately.
How I can export the simulation as separate objects?
Lets say I have two collapsing buildings where both interact each other. Is hard to manually select them after simulation (voronoi, etc.)
What I'm doing now is do one simulation for one building, then in next simulation use as a collider for the other building, but is not the proper way.
Probably there is a easy way but I can find solution.
Thank you.
Thank you.
