tyBoolean issue
Hi!
I made a simple flow with some animated objects as shape geometry and returned them back via export to objects as reference nodes.
The exported objects work fine, but as I picked them in tyBoolean to fuse them together, there are some crazy mesh distortions and gaps from the point on when they collide.
Don't know if this is a bug or just normal behaviour.
I attached a small video and the max file here.
.mp4   WindowBirth02_Boolean_02_Camera001_preview_v002.mp4 (Size: 1.96 MB / Downloads: 9)
.max   WindowBirth02_Boolean_03_postME.max (Size: 764 KB / Downloads: 6)
Greetings!
A union of concident faces like that is basically the worst-case-scenario for a CSG operation and it is guaranteed to have a high failure rate.
I would recommend moving to a VDB workflow in tyFlow for something like that - you won't run into the artifacts. The downside is that in order to preserve the hard edges you'll need a decently hires grid.
Indeed I allready tried the VDB alternative but as you said i had to raise the voxel-grid resolution very high for keeping the crisp edges. When I cache it out the last few VDB frame files reached over 100MB each. Additionally I had the issue that I don't get it stop calculating after it has reached its final desired form.
I asked for that in these threads:
Crisp edges: http://forum.tyflow.com/thread-1824.html
Stop building: http://forum.tyflow.com/thread-1825.html
But so far it works fine, here I attached the video Smile :
.mp4   WindowBirth02_Boolean_03_VDB_Camera001_preview_v002.mp4 (Size: 1.78 MB / Downloads: 5)
