TyCache bug?
Hello, I think I found a bug in TyCache, let me explain:
I have a TyMesher wich I geoCached trough export particles. This Tycache needs to have one object excluded from refrancions trough vray properties but when its rendered it ignores this while in the TyMesher were working ok.
I found that if I uncheck "Enable Vray Interface" in the rendering options of the TyCache it renders ok with the object correctly excluded from refractions. So I assume that this is some kind of bug, isn't it?
I'm usin 3dsmax 2020 and last Tyflow version 016089
Which version of VRay?
Vray Next update 3 (4.30.00 build 00001)
Are you rendering CPU or GPU?
