Chaos Cloud Bug with Material ID assignments
I'm working a big project and we are using VRay Chaos Cloud
Using max 2021 and VRay 5 HotFix 2
Here is a bug that seems to be specific for that rendering system.
Create a scene with a geosphere and tyflow
Select geosphere and create a preset flow 'Simple Scatter Flow'
Assign a VrayMaterial to the TyFlow
Submit to ChaosCloud
Should render fine.
Bug 1
Shape operator - Material ID Override check on
OR
Add a MaterialID operator to the event.
TyFlow Particles do not render or the render will fail.
This scene renders fine locally.
Andy Murdock
Have you raised the issue with ChaosGroup?
No, and after I wrote this up I was wondering if it was on their side. I will send them the same bug report.
EDIT: I just now submitted the bug to the Chaos Cloud forum.
Andy
If you're using VRay GPU, the tyFlow implementation was written by them, so not much I can do.
If you're using CPU...what's the error message that the machines return?
