Time Test
Hi!
I wonder how the variation parameter will work exactly.
If I have a time value of 25 and a variation of 25 then the generated value can be randomly from 0 to 50? Is that right? I assume that because there is a "±"-sign in the operator when its in the event evaluation list.
Is it possible to have the variation just in one direction? Positive or negative? So that when its positive the time will never go below the 25 and so the resulting test range including variation will be 25 to 50?
Hope its clear what I am asking! Smile
Thank you and greetings!
Well, you just do it the same way. Smile
If you wanna range from 25 to 50, you type time to 40, with variation of 10 to 15. Smile
Thats a solution. Simple math Wink. Thank you!
