tyconform offset question
In tyconform z offset is relative to target surface normal ?
sometimes when I use raycast z=-1, and I set z offset, instead of moving out of the target surface it moves in x direction.
If I reset transform my target object, then it is ok.
But certainly there is some case where I cannot reset my object.
If you have a replicable scene, please submit it.
(10-09-2020, 01:10 AM)tyFlow Wrote: If you have a replicable scene, please submit it.
Here is a scene.  :-)
.max   offset 01.max (Size: 688 KB / Downloads: 341)
Thank you for the scene...that is indeed a strange and unintended result, and I'll make a note to look into it further and hopefully get it fixed in the next build.
Big Grin
(10-15-2020, 05:22 AM)tyFlow Wrote: Thank you for the scene...that is indeed a strange and unintended result, and I'll make a note to look into it further and hopefully get it fixed in the next build.
Thanks !
