Fuse operator....
Here's a description of my flow.....
I have positioned my particles with random scaling on tyicon.....Applied fuse operator to remove the overlapping objects - when checked Display fuse sphere - it shows perfect,
but if I add cloth bind operator after fuse operator - the process of fuse operator changes and now when i check Display fuse sphere, its shows sphere on the vertices......so is it a bug or fuse operator is calculated at the end - no matter where its placed
Well I can send out particles to different event after I am done with fuse operator....but thought it might be a bug or something
thank you
Nayan Bodawala
The display happens at the end, not the fuse calculation. This is so the flow doesn't need to be recalculated just because you've toggled the display setting.
