Export VDB issue
Hi!
I'm trying to export VDB, but all files I get seams to be empty (1kb size).
I thought the grid must be empty, but VDB Display operator gives correct preview in viewport.
Have you selected the right channels to export? For example if you haven't created a density channel in your flow, it won't be exported.
If you believe you have, please upload the file so I can take a look (or send to support@tyflow.com)
I cheked it again. VDB Display shows values betwin 0.0-0.99 in density chanel. As I understand, there shoud be cell values writed.
 All my exported vdb files contains something like that "BDV    ŕ         9a6b6253-f489-43f9-8032-2b7ce3eef802          LevelSet   Tree_float_5_4_3     "
So I attached my scene
PS.
Thanks for tyFlow! Smile
I almost abandoned 3ds MAX aftler 20 years of using it. Pflow is nice tool to me, but realy time consuming. tyFlow is realy game changer in my workflow.
right here
.max   tyflow VDB test.max (Size: 920 KB / Downloads: 214)
Thank you for the file, looks like a regression in the VDB library update of the latest build is preventing exports. Should be fixed in the next build which will be going out sometime this weekend.
