Animation continuity across events
Hi.
I'd like to keep geo animation after moving it to next event.
I have a sphere shape with some noise and wave animation, it is set to "event" sync. Then I'm moving it to another another event after time test.
There's only a scale operator there. But when I move particles to this event, animation stops. How do I make it continue the animation going?
Thanks!
I'm fairly new to tyflow.
Best regards
Paul
If you're using the Shape operator for your animation (as opposed to actors), you'd just put the same Shape operator in the next event as well, and set the animation to sync to particle age instead of event age.
thank you. Worked like a charm
