About exporting mesh without animation
Hello. I have dropped the objects by breaking them down with tyflow. However, I want to export mesh without animation while exporting mesh to max. I just want them to stay where they fell. How can I do that. Thank you.
Add mesh operator, uncheck "render only", select TyIcon, and just go to Tools - Snapshoot.
First of all, thank you for your answer. I did what you said and converted the object to mesh. But when I go back to max and press the animation button, the animation starts playing again. I think I'm doing something wrong.
Did you turned off , or deleted Tyflow? You should do that, so you only see still mesh.
This is how snapshoot should look like:
https://help.autodesk.com/cloudhelp/2017...1505FC.png
Snapshoot basically "screenshot" the selected object and it's mesh, and creates a clone of it.
You should hide or turn of, or delete original mesh after that
Thanks for help.I understood.Regards.
