Display Data 节点 BUG
The Line to Target display in the Display Data node is unstable, and CACHE N/A always appears in uncertain frames.
.max   aa02.max (Size: 664 KB / Downloads: 112)
It's not unstable, it's just that custom float data is not saved to cache by default, and if it's not saved to cache, only the most recent frame will contain it.
If you need to display data dependent on custom float/vector/tm, be sure to enable their cache in the Cache rollout.
The unpretentious answer contains great wisdom
