The "attribute test" of particle angle change.
HI,Tyson!
If the particle rotates 90 degrees (or local coordinates) in the z-axis direction, how to test the output?
I tried "spin."_ I found "spin"_ Z "only tests the value, not the angle change. So how do we test the output "particle angle" change test?
thx
You can do this with the Script operator. I've attached a file showing how.
The key is to measure the dot product of your normalized vectors, then calculate the acos of that dot and then multiply by the radian-to-degree constant, to get the angle between them.
.max   measureAngle.max (Size: 696 KB / Downloads: 153)
Thank you for your papers. I'll study hard. By the way, will this particle angle test be added to the property test operator in the future?
Perhaps at some point.
Thank you. I'm looking forward to it!
