sequence texture
how can use a sequence texture to change values like scale and gravity?
I tried to get this trick with the displace modify but it did not happen.
Surface test.
Set it to texture, and copy-paste instanced map from material editor.
Connect it in the new event where you will set up gravity, scale.. etc.
(09-27-2021, 03:51 PM)d4rk3lf Wrote: Surface test.
thank you.
