How to make Actors walk on surfaces
Hi Guys,
I was wondering if there's a way to make  ( walking ) actors stick to a  ground while they are activated by animation.
I would like to make them walk on a noisy surface towards an object ( with find target ).
Thank you !
Cheers
Tamàs
From the Actor operator, send the root particles out to an event with Object Bind (surface mode, sticky:0%, rotation disabled), and also a Rotation operator set to surface align and then add your Find Target above the Object Bind. Basically the same way as you'd align/move any type of particle along a surface.
(12-03-2021, 06:32 PM)tyFlow Wrote: From the Actor operator, send the root particles out to an event with Object Bind (surface mode, sticky:0%, rotation disabled), and also a Rotation operator set to surface align and then add your Find Target above the Object Bind. Basically the same way as you'd align/move any type of particle along a surface.
Thank you so much, works smooth!
