collider problem - objects go through objects
I have a collide operator between a cloth (cuda) object and a ground. when I put a force (gravity) to it, some vertices of the cloth go through the ground when they shouldn't.
The tyflow time set is set to 1/8 frame. the bounce interaction to 0.
I don't know why that is or how to solve this.
Any suggestions?
Thank you
Can you post the file?
yes. Attached
.max   Ty_Check_inflate01.max (Size: 2.68 MB / Downloads: 94)
You're deactivating particles, but you're not stopping the motion you've applied to them prior. Put a Stop operator in Event_002.
Perfect. It works flawlessly. I was sure deactivation particles basically means stopping their action.
Thank you for the quick response and solution. TyFlow is such an awesome tool.
Glad I could help!
There are some situations where you want to conserve the momentum of particles after deactivating then, so that's why it doesn't stop them by default.
