Export tySplineMesher to Objects
I've created a tySplines event with a tySplineMesher in the modifier stack. Now I want to paste the simulation into another document. How do I convert the tySplineMesher to a keyframed mesh Object? I tried the Export Particles, but that just gave me the nodes and not the tySplineMesher. I need to be able to move the imported mesh to a different position and adjust the start frame.
You can export to tyCache and then set coordinate mode to 'local' (to move it around) and use the Timing rollout to adjust the start frame.
(02-28-2023, 02:40 PM)tyFlow Wrote: You can export to tyCache and then set coordinate mode to 'local' (to move it around) and use the Timing rollout to adjust the start frame.
Fantastic. That all works really well. Thanks
