tyCache inherit material issue
tyFlow Pro 1.018
Redshift
Max2022
I swear this used to work, but we have a tyflow that's using a tycache (with a few seperate elements) in the shape operator, each element has it's own material.
It seems like tyFlow isn't inheriting the material from the tycache, even though the tycache renders correctly on it's own.
We've tried a few combinations of particle interface etc, but nothing seems to fix it.
The only thing that works is actively pointing at the .mat file included with the tyCache but seems to assign the materials in the wrong order. See attached image.
Unfortunatley I can't send the file as it's under NDA, but any help with this would be appreciated.
[Image: image.png]
Hard to say what you're trying to do here, but the inherit material option takes the material assigned to the reference node. It doesn't take instance materials loaded into the tyCache from disk.
