tySplineMesher smoothing/Interpolation
It would be great to have a face/normal 'Smoothing' option on the tySplineMesher, as well as an interpolation of any linear spline points to bezier for smoother looking splines.
The spline interpolation should be done in the base object....all max splines (including tySpline objects) should have an 'interpolation' rollout where you can set those values.
As for smoothing, do you mean an option to smooth the mesh by face angle or whatever?
(04-02-2019, 10:37 AM)tyFlow Wrote: The spline interpolation should be done in the base object....all max splines (including tySpline objects) should have an 'interpolation' rollout where you can set those values.
Thanks. Yes, the smoothing option for face angles/normals can be found in other spline-meshing plugins, so would be nice to see here.
