rain simulation
Hi really love the plug in, coming from pflow it's night and day
I'm having trouble setting up a simple rain simulation, when I render (cpu vray progressive) every time pflow resimulate instead of using the cache, I have checked use half frames cache too so idk what could I be setting wrong
another issue when the simulation is finished that there are no particles getting born, not even present, tyflow still recalculates and delays the start of each frame a lot, can anyone help me with this please?
You can turn on "print sim reset info" in the tyFlow Debugging panel, to have the listener print out the reason why a sim is being reset. It'll tell you the operator and parameter causing the reset. Maybe you have a render-only dependency somewhere (example: a Turbosmooth on an input object with render-only subdivisions).
