Why does the typarticleSkin modifier have no top surface break function?
Why does the typarticleSkin modifier have no top surface break function? Is there a plan to add?
tyParticleSkin is history independent. The only way to have face breaking (like PFlow's particle skin) is to literally delete faces when they become too stretched, which causes popping in the resulting mesh (the popping also occurs in PFlow's modifier). It seems like those types of artifacts wouldn't be acceptable in a production, no? I could never use PFlow's particle skin tearing for the same reason...
It seems that I only use video to prove that the results I get here are completely different from the results you get.
