Constrained rotation based on Force
Hi all,
Its probably very easy to do but im a bit stuck :/
Im trying to create an an effect where the particles dont move and only rotate on one axis based on a force.
something like the image attached.
I tried using travel direction and resetting the position but I cant really the desired result as travel direction wont let me constrain to one axis.
anyone have an idea ?
Not sure if I fully understand...
Is this maybe a solution?
.mp4   force_limit_pos_Perspective_preview_v002.mp4 (Size: 14.54 MB / Downloads: 25)
.max   force_limit_pos.max (Size: 684 KB / Downloads: 22)
Thanks for your help!
I cant open the file ( stil on 2022 ) but I think this is not quite what im after.
I hand animated the effect im looking for, the particles should only rotate on their Z axis. Like a weather vane basically.
Im trying to visualise a curl noise pattern with a lot of these rectangle shapes.
Edit : I spoke to soon! :] I recreated the your screengrab and this is basically what im looking for, thanks again!
.mp4   Tyflow rotate_2.mp4 (Size: 1 MB / Downloads: 23)
