surface test "lag"
Ive been using a surface test operator  set to "nearest velocity" to pass particles on to a surface force operator, for the effect of attached particles flying off an object when it moves.
however there is a lag. if the object moves, the particles are triggered on the next frame it seems.. this means they momentarily pass inside the object.
i have worked around this by passing the triggered particles into a new event with another object bind operator in, and then a time test set to one frame.    after this one frame, they pass on to the surface force event.  this works, but seems unnecessary.
i am not sure if this is inevitable , or a bug.
it would be good if the "surface test" operator could "look ahead" or something so that the movement of the particles is better synced with the object they are affected by.
Can you post a screenshot of your flow, and/or send the scene to support@tyflow.com?
