Network rendering
Just tried to render some tests across our network, copied the TyFlow plugin to the max plugin directory on 4 machines, but each of them is stuck on 'transforming vertices'.
I accidentally opened up Max with the server (this is via backburner, unfortunately) still running on one of them and the render began. So I don't know if that might be part of the problem?
I've tried caching the flow and moving files to local locations but still no joy - unless I fire up Max at the same time.
Let me know if you need any more info!
I also had network rendering issues as posted here:
http://forum.tyflow.com/thread-23.html
Don't know if the problem is related, but thought I'd mention it.
Thanks guys, I'll try to figure out what's going on when I get the chance Smile
No rush! You have honestly already done so much!
